I changed the screw on the lever because the thread had gone. If the wire on that side shows no continuity, how can it be a ground problem. I've tested every single wire in that connector to the wiper switch and the only one that doesn't sound is the brown wire that feeds that turn signal.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
