Talked with Eric from JW at PRI. He could not remember the exact spacing on his flywheel. He gave me a figure but it does not sound correct if you run starter spacers. Do you run washers to correct converter pump engagement or have any motor plate spacing built into converter?
The reason I ask, is no sense in two companies making the same flexplate. My next run of bells I may deal with JW. The price they quoted was $375 for flywheel and crank converter adapter. Does this sound correct?
