thanks for the help everyone. yea we got it going. it was a bad lift pump. we just rolled in 10 hours straight through
My diesel didnt have a in tank lift pump(just the
primer pump) with the P pump but I installed a currant
in tank lift pump about 5 years ago to up the supply
pressure.. now I run 24#-30# supply pressure...
you could have strapped on any small low pressure
pump in line and got you home.. I have a pump in
my truck just in case... good to hear your all set
and back home
yea this one is on the side of the motor just like my 97 dually. how did you guys run the fuel lines with an electric pump?
