"Are 67 and 72 Dart rear glass openings different sizes or am I missing something? Would it work if I used a gasket instead of buytl?"
You have to use gasket , both cars are designed for the rubber seal . I can see now why its 1/2 inch too short. Glass will basically fall through.
