Who has a roller lifter that basically just drops in ? I've heard stories of some that uncover the oil holes and some that you have to grind on the block to use. Are there any that work good that just drop right in. I have a kit to tube and peen my block, but I have heard some go right in and you dont have to do a thing. It will be a pretty big roller with 1.7 ex rockers and 1.8 int rockers. Thanks for any help
We have the cam's base circle cut down while grinding the cam, to drop the lifter down in the bore more. If done right, you can run as much as a .470 lobe with my lifters.
I'll post pics of them later, but without a reduced base circle, .420 is about the safest to go unless it's checked some how with an existing cam.
Brian
Brian Hafliger
