If a person does use the Copper RTV, do you apply it around all ports and on all connecting surfaces?
That's what I did except I used the black rtv.
You better pray you don't have to take that intake off , ever ... it's going to be a mess getting that off .
OP , the paper gaskets that come with the valley tin are .030 thick EACH , of course you will have alignment issues.
I like to use an .015 thick gasket to help seal because I hate having to scrap off sealer So I usually have .015 taken off the intake so I can use them .
