Can't seem to get the water to circulate in the motor since I put it back in. It now has a hardblock fill to the bottom of the water pump holes. I tried jacking the front end up and pulling the last header bolt on the passenger side that goes to water and nothing. Anyone have any other tricks? I remember when had the 440 with a tall fill in it I had similar issues.
Start warming up the engine.. I have the same issue
with SBs... cycle the pump on and off.. it should
start pumping when it gets warm... also squeeze the
lower hose a few times
