Is it a conversion or a Pertronix distributor? I have a Pertronix distributor and it doesn't use a ballast resistor. You may be able to bypass the resistor to see if it will start.
I do have the original distributor converted, and the original ballast resistor.
So if I eliminate the BR, what do I do with the wires?
IMO.. throw the Pertronix distributor in the trash.. get either a Mopar electronic conversion kit or if low budget get a good used electronic distributor.
... should he get an ORANGE box too ???
Seriously there have been so many issues with MP distributors and phasing for DECADES , hearing now that even the NEW distributors with the adjustable mechanical advance has phasing issues .
I put my old pertronics set up in a buddies car witha MADE IS USA flame thrower coil , I need to look at the direction and probably switch in a phony ballast, it's running fine right now but I don't wantto burn up the GOOD MADE IN USA parts vs the CCJ they sell now ...
