Try a razor blade and finish it up with steel wool.
Used to remove overspray off windows at the body shop.
This is a sure way to destroy your glass permanently.. Do not do this.
Sure way, I don't think so... A razor blade and the right steel wool won't hurt the glass as at all.
Obviously, you two have never tried it or worked in a body shop.
Steel wool works on chrome too.
OP, if you like, just Google it first, you'll see.
Mo' Farts
Moderated by "tbagger".
