Quote: Dap, What is your fuel pressure set at with the motor idling? I just installed the same fuel system you have and mine is trying to quit at the mph lights and I am only running 1/8 mile.
I have 29 psi at the fuel log and the regulator is set at 7.25 psi. FP is rock steady.
