You might have the E body springs on there. If the shackles are flat up against the frame rail. Or, try lifting the car up via the frame and get the tires off of the ground, then try to pry the shackes down. Mine sorta "over centered" themselves during install on my 71 b body. But be careful, when they let go, they really let go. Something is definitely wrong here.
