Your description is what a normal 88 tbi v6 or 318 is like. No ballast, No VR, its all in the ecm behind the battery in the fender.
corret. I have a 88 that has been converted from tbi-pcm to a elect vac dist with ecu wired in the 88 harness.(all tbi/pcm wire removed) also has the VR wired into the harness and is mounted by driver side hood hinge area.
the lights/dimmer/blinkers/wiper are all on turn sig switch with a muti function switch. nothing but crap under the dash on 88-93
