Look tucked in behind/under the battery/fender area I used to have an 87 D150. All the lean burn stuff was in there. An astonishing number of wiring problems turned out to be tracable to the bulkhead connector (where all the wires go thru the firewall in a bunch with a bolt holding them in).
