If those are like the E-body ones, they're held onto the control lever by a devious little metal clip. The control lever has a small hole in the end, and the clip has a semi-circular depression that clips into the lever hole. It's not just a force fit. I think I ended up using a tiny screwdriver or blade to get mine off, but it was a fight.
