Measuring it at line pressure outlet on right side. Trans man says it should be about 160 psi. Not sure of brand, but it is a reverse pattern manual w/ low band apply. Just wondering if low pressure could cause 14% slippage. Car launches good, but slips all the way down the track.
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
