It's a RMVB. What causes low line pressure? I don't know much about auto transmissions. Could bad clutches do this? Trans is only two years old.
Being a RMVB your pressure is preset in the VB.. I
forget if you would have a throttle pressure on that..
I know the trans brake you dont get throttle pressure
and its locked... but I have the trans out of my Rampage
and between a bad shifter cable adjustment and low
throttle pressure it FRIED the low clutch(all the fiber
was gone)and it slipped
