Quote:Quote:Quote:[quoteSo tell me IF your throttle is stuck just how do you lift??? Couldnt see the vid on my end. From all the text I get that Mike tried to drive through it, but could of lifted to save it a few times. Hindsight is 20/20 could of done this/should of done this. Ive tried to drive through it a couple times myself.But a stuck throttle is complete different issue. Didnt know that was the case. listen to the run and tell me if it was stuck you can hear him lift right before it went up on 2 wheels.
