Quote: My KOS Demon has brackets on the frame (or K frame) for something like this. I did not get the motor attachments or connectors. Thanks for the pics. Any more?
Anyone fab up the motor side attachments or is that a unique deal?
Basically thats just a L of angle iron or alum angle type of a deal... if you run it over 3 or 4 bolt holes on the pan then the L of it hangs down with 1 hole in it (the buld of the lower L side can be cut off and give it a nice shape.. the lower hole will have a heim bolted to it then forward in a thick wall tube or moly tube with threaded inserts and a L welded to the K to mount another heim also in the tube
