Quote: So you guys are saying that with cal tracs and a big slick with the stock leaves I should be able to make it hook decent?
It might hook.. but with a 4-link you get plenty of adjustment to make it hook... you arent moving the IC length on springs but you can with the 4-link.. by the time you buy the caltrac you can build a 4-link but you would have to build it
