The Precision ones are junk. I tried them on 2 trucks with the same results. One set about 5 years ago, and another just recently.
They're nice and easy to install yes, but you have to SLAM the doors to get them to latch. Cracking a window helps, but you still have to slam them hard.
The ones that were installed on the other truck 5 years ago have softened some, but still requires a good slam of the doors.
I've tried adjusting the door and latch outward which did help some, but it shouldn't be this hard to close a door.
Iv'e used precision once before never had a problem with them ive compare the door seals to the original 89 rams and they are the same thickness other than being used.
