Re: nitrous, turbo, procharger or all motor?
[Re: dizuster]
#1644320
07/10/14 12:04 PM
07/10/14 12:04 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
I doubt you could build a low deck, stage 6, motor with the proper sized turbo to only run 10's. It would probably do that on 4psi...lol
If you want a 10 second turbo a body, you don't need those heads, or a stroker.
A 400/383 steel crank, Eddys, and a 80mm t6 turbo will give you 9 second pump gas capability easy. On race gas or would make 1000hp pretty easy.
Yup, also. Save your money on the heads and stroker part. Look at what we (the turbo guys) run for parts and we are very mild and in the 9's.
I have Eddy heads on a 389 sb with a .520 hydraulic roller, 3.55 gears, 3000 converter.
I think dizuster is running a similar setup.
Entire Thread
RapidusMaximus
07/09/14 03:14 AM
Bigcube
07/09/14 03:28 AM
hemi-itis
07/09/14 03:38 AM
StealthWedge67
07/09/14 03:40 AM
rickstershemi
07/09/14 03:47 AM
RapidusMaximus
07/09/14 03:59 AM
MR_P_BODY
07/09/14 04:41 AM
tubtar
07/09/14 05:00 AM
383man
07/09/14 05:22 AM
RapidusMaximus
07/09/14 11:08 AM
an8sec70cuda
07/09/14 02:24 PM
RapidusMaximus
07/09/14 03:51 AM
Thumperdart
07/09/14 06:38 PM
johnnycuda
07/09/14 07:13 PM
Mr.Yuck
07/09/14 02:46 PM
TheOtherDodge
07/09/14 03:50 PM
Porter67
07/09/14 04:04 PM
mshred
07/10/14 04:54 AM
RapidusMaximus
07/10/14 12:10 PM
dizuster
07/10/14 02:47 PM
mshred
07/10/14 03:54 PM
BobR
07/10/14 04:01 PM
TheOtherDodge
07/10/14 04:04 PM
SLOW67
07/10/14 04:56 PM
MR_P_BODY
07/10/14 05:42 PM
TheOtherDodge
07/10/14 07:53 PM
gregsdart
07/10/14 08:09 PM
FastmOp
07/11/14 06:19 AM
RapidusMaximus
07/11/14 11:28 AM
6PKRTSE
07/11/14 06:59 PM
Mr.Yuck
07/11/14 07:05 PM
Mr.Yuck
07/10/14 05:24 PM
polyspheric
07/09/14 06:34 PM
TheOtherDodge
07/09/14 07:32 PM
Cab_Burge
07/09/14 08:33 PM
Thumperdart
07/09/14 09:13 PM
RapidusMaximus
07/10/14 02:01 AM
