Thank You Commando1. The worm gear preload is the 'big' one if I'm not mistaken. The 'over center' or 'cross shaft' adjustment never did much for me. Turn it in too much and steering will bind. In other words coming out of a turn, the wheel won't return be itself. It will need minor input. (this is in way too far).
