we have a winner i need the 5th piece 2nd row 2nd one looks identical. on ours the block snapped off the lever. anybody have one?
#4 & #5 are the same, both have the slide adjusting block held on with the hairpin.
if the stud broke off you need the block not the lever.
unless the stud is on the lever as in top row 2nd one. that looks to be a stud/lever.
either way I have them. returned your PM
