Heres a trick if you don't Mind running Brand X Parts on your truck A Stock Chevy front shaft, from Late 70's Early 80's will fit perfect in 74-93 Dodge with 8" lift. You just have to switch out front yoke with GM Unit.I have done this on my 92 Gasser (Dana 44) and My 91 Diesel.(Dana 60) Both are lifted 8" (Well diesel is 6") But equal to 8" on gas truck.
Good info. Thanks. I'll go this route first, if I can find one.
