Do NOT run shims. It will steer like he11 and pull all over the road. And you don't gain much by doing it. As long as you lengthen the driveshaft and clearance the cv so the driveshaft can articulate at the angle, it should work okay. Dropping the engine and xfer case down is an option too.
