the RPM is noticeably taller and it is a single plane.
The Performer RPM is not a single plane. As far as good street manifolds go, the Edelbrock Performer RPM and the Holley Street Dominator are about the best there is for a fairly mild engine. The Holley SD is much shorter than the RPM, so I doubt it would work w/ the air grabber setup either.
