So I used an Edelbrock Performer (not RPM) on my 440 and I think it is a tad taller than the factory manifold but it clears fine in my Cuda even with a rubber carb spacer.
Sure you don't have an RPM? As a9sec70cuda stated, the RPM is noticeably taller and it is a single plane.
