Hear what you`re sayin and as stated, comparing Dove to any of the mentioned bad azz rockers is apples to oranges and if you`ve been around long enuff you should of heard that by now...........
Right on Dom....
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
