The so-called converter drainback valve actually prevents the high-mounted cooler in the radiator side tank from draining back through the converter. Nothing can prevent the converter from draining back.
Anecdotal tales of lockup converters lasting hundreds of thousands of miles are the exception rather than the rule. If given the choice of a factory or aftermarket lockup converter I wouldn't choose the factory.
