Hi Chip, Motor made 1042 hp @ 6400 and 950ft/lb @ 5300 on Todds dyno. 11:1 cr with 93 octane. Pump gas motor, racing fuel is so expensive over here. It's a 655ci Indy block with 600-13 heads, raised cam, 4.840 bore centre line. Cast intake 2x4. Wet sump. Should be very streetable
Simply bada$$. Can't wait to see pics and hear how it runs. I'm gonna need some video...stat. Thanks.
