Tried moving other direction and nothing. The back cone, front collar and long outer shell all move together. you could actually spin it from the engine bay as well (outer shell sticks out about 5 in on firewall). So if these bolts are to keep the front collar and cone together then they are not separating at all right now and when I eventually put the lower steering column bracket back on that will lock in the outer shell, cone and front collar in place. is the front collar and the cone suppose to move independent of each other when the bolts are out??
