Hey guys,
I am working on another article for HH. I have access to a very original car that was built a bit early, in the month prior to the scheduled production date on its fender tag. Looking at the date codes on it so far has been fun & I have started a spreadsheet to track them.
Not all of the possibilities listed below have been checked on this car yet, but I have seen them on other 1970 model year cars. If you know of something not shown, please mention it so I can add it to the list and / or check it on this car.
I will edit the list as more possibilities are reported.
Thanks!
Barry
AC clutch field coil *
A/C evaporator/drier *
AC hose *
Air Grabber switch
Alternator
Battery
Bellhousing *
Blower motor *
Bumper jack mechanism
Calipers *
Caliper mounts *
Carburetor
Carpet tag – front
Carpet tag - rear
Clock
Coil
Console *
Convertible boot cover
Dash pad *
Dimmer switch
Differential ring gear
Distributor
Door jamb switches
Door panels *
Engine casting date
Engine final assembly date
Engine mounts *
Exhaust manifolds
Engine main bearings
Engine rod bearings
Fan belt *
Fuel pump *
Gauge cluster
Harmonic balancer
Headlight switch
Heads
Headlights
Headlight door motors
Heater box *
Heater fan / AC switch *
Hood hinges *
Hood latch
Horn
Horn Relay *
Horn switch
Intake manifold
K-frame
Lower control arms
Muffler(s)
Mylar door sticker
Oil sender *
Outside mirror glass *
Plug wires *
Power steering belt *
Power steering hose *
Power steering pump final assembly day *
Power window motors
Radiator
Radio
Rear window defogger
Rear window defogger switch
Rear end gear housing casting date
Rear valence
Scheduled production date from fender tag
Seat belts
Seat frame - rear, bottom
Seat frame - rear, top
Seat frame(s) front
Seat tracks front
Seat upholstery
Shocks *
Space Saver spare inflator bottle
Speaker(s)
Starter
Steering column *
Steering pulley *
Sure grip carrier
Tachometer
Temp sender *
Thermostat housing *
Tires
Transmission casting date
Transmission final assembly date
Transmission mount *
Transmission tail shaft
Trunk mat *
Torsion bars *
U-joint straps
Vinyl top
Voltage regulator
Washer motor
Water pump *
Water pump housing *
Wheels
Windows
Wiper motor
Wiper motor switch
