We have blasted the pans before and what you do is seal off the inside of the pan. I use cardboard and the wide green painters tape and I make sure it is sealed off so no sand gets in. rinse it before you take off the tape etc. After the outside is clean then do the inside with brake clean or something, then a Good blow dry.
Paint or primer away.
David
i was thinking of that, sealing it off really well.
i'll give that a shot. easier than trying to get all that damn primer off by hand!
thanks!
