Going off of bad memory here... When I picked my engine up, I was blabbing with the builder about weird builds. He says he had one that there was some type of plug back in behind the oil pump that had a whole drilled too deep and into the water jacket.. Not sure if it was a BB or a SB.. He said it was an easy fix by either filling the hole with sealer or tapping it and putting a plug in it?? Kevin
71 gtx.....
