i think the nhra rules say all c-clip axles must be altered to make them safe----and as far as strength yes the 9.25 is strong---but pinion placement is more important than ring size----thats why stock 8.75 is stronger than a stock 9 inch----the 9 inch pinion is at the worst spot at the bottom of the ring gear----the strongest position is near the center...
