i use an ultra club, when my cars are parked. this helps keep the amateurs away from the idea of stealing them. you can also get a cool lock that goes from the brake pedal to the steering wheel. making it harder for them, will usually make them look for an easier mark. a hidden kill switch is also something to consider.
I'm looking for something that will slow them down, cause them to reconsider in that it would take a lot of effort to saw through steel mesh just to get into the cab.
even if you secure the back window, you still have side windows. kill switch, and/or shut off valve in the fuel line, makes it harder to get away, if they get in.
