Thank you for the how to on making them fit a reg cab The other 5 pairs of bases that I have will get used for sure now with a set leftover in my other trucks
Larry they look great in there
On the passenger side I drilled the holes in the square tubing to mount to the seat and then drilled holes about 2 inches back to mount the tubing to the seat base.
