Another option to help your project might be a newer 727 with a lockup converter. There are companies that build converters for them with more than one lockup disc for hi hp apps. On the cam, I don't agree with a wide lobe separation for a low end torque build. It hurts both ends of the power range when you don't have big heads and valves for the cubes, and stroked 440s are hurting there.
