to the right of the instruments/speedometer/AC vents
Whats diffent here?
And if your redoing the wiring your almost better off pulling the window and the dash so you can work on it with out a head rush.
The under dash wiring harness replacement was done a few years ago and with the dash in. The car was painted and the glass and most of the interior were removed at the time. When I had a few electrical issues I found the burned wires and bad harness, at that point I wasn't going to pull windshield out and did the replacement with one big head rush
