Make sure you're using a good set of converter bolts. NOT the Mopar Performance bolts. Get a set of the 12 point ARP converter bolts. Use red loctite on them. Spray the threads in the converter out w/ brake clean to make sure there's no grease or oil in them.
Something out of balance will cause them to loosen...as well as detonation.
