I read the P sheet and it says to top coat with paint or a 2 part primer within 7 days while it is still in the window or it must be scuffed and retoped with more DP.
I asked the paint store if after that window, if it would be ok to scuf and top coat with 2K primer with out the coat of DP. They said it should be ok even though I have broken the rules.
Reason for wanting to skip the re-coat of DP is it is very costly.
I will be blasting some "Donner panels" and using the DP to keep
![](/ubbthreads/images/graemlins/thumbs.gif)
them for futher use down the line.
I know you can just top coat E coated panels with a light sand or scuffing so should the DP be that much differant?
I also see this being a problem while working on the car
{ie} Say ya get the engine bay ready, coat it with DP and then move one to another section the same thing would happen
