So, you're saying that you can hook the jumper cables directly to the cable ends that screw into battery, and it starts right up? Then the problem can only be at the cable ends and how good of a connection they have to battery lugs...(silly side terminal and all.) Or are you using the provided junction posts that make it easier to jump rather than getting to the hard to access batt posts?
