Most of the dana 60 I've seen for the front of one ton 4whd where 60-2 casting, that # is cast on the top of the frontof the center section above the pinion gear I have tried to contact Dana Spicer Corp. many different times about trying to use a standard rear gear set in them, I have not been able to get a response from the Company yet
