Probably going to turn it on the crank grinder?
I would hope so........SURELY they are not just gonna chuck it in a lathe and go to town. If they are, he needs a new shop......LOL!!!!
Monte
Monte ,
You been at this WAY too long to not think it couldnt happen! You shouldnt be surprised at some of the " suggestions" that the customers can offer.....lol
I've actually had this a fair amount of times, where the journals arent sized correctly, and when you have to explain a day or two delay in the build process to fix the cam, they ask, " cant you just chuck it in the lathe and polish it a little with some sandcloth".?
It kind of falls into the " can you throw this on the mill and give it a quick cut", or a " just needs a quick turn in the lathe"....oh boy....
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
