What I would do is support the truck on jack stands, then put a floor jack so the lift pad is on the inner lip of the drum and slowly raise it up. I use this on big bus drums- make sure the shoes are as loose as possible. I'm NOT telling you what to do Blah Blah Blah www.legaldisclaimer-ect
