Re: Who makes the best carburetor base gaskets?
[Re: pjc360]
#1567823
01/25/14 12:26 PM
01/25/14 12:26 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I never thought about the spacer being warped because it's basically brand new , it only has like 4 or 5 thousand miles on it. But it makes sense. I have a 1/2 4 hole phenolic spacer, maybe I should run that one instead. How do I check the spacer for being warped?
Check for flatness using a straight edge, metal ruler, piece of bar stock, whatever just as long as it's straight and flat. Check corner to corner, side to side and catty corner. Top and bottom, also check the intake flange and carburetor base plate.
In response to your PM here is a link to the catalog. Open the catalog and scroll down until you get to the carburetor gaskets. All the info you should need for them is there. Keep scrolling down for the price sheet.
http://www.superformanceproducts.com/catalog.php
If you would like to purchase some click on the "Distributors" tab and choose from the links where you would like to purchase them from.
Any questions just ask ![](/ubbthreads/images/graemlins/thumbs.gif)
