Quote: Those pieces are not attached to the floor pans from AMD. They come loose in the box. At the last couple I bought did.
Interesting. The guy at AMD certainly didn't seem to be aware of that, unless he just didn't want to disclose it. So, I presume then that it is up to the purchaser to attach them to the floor pan. Do they get spot welded in? I assume they could also be attached via sheet metal screws, or nuts/bolts, but that would require drilling into the plates and the floor pan.
