Quote: Some of you guys need to go price this stuff. An ls 7 is about 13000 for just the engine, an Ls3 or 6.2 is about 9000, just the engine. Chrysler sells the 6.1 for 9000 with everything you need to make it run except the fuel pump. I think you can buy just the 6.1 for around 7500. Mopar looks cheaper to me if you start with new stuff.
There are no more factory 6.1 being produced. You will need to purchase the 6.4 which in my opinion is a better block. This year the heavy duty rams have the 6.4. There should be cores available soon. Matt
