It's easy to do.. Just stay at a Holiday Inn and "BAM" you're there..
Yes, my motor dynoed right around 950 hp. And the car runs close to where it's supposed to "All Out" (8.70's @ 153+ --- 2800' - 3500'DA). Right at 3000 lbs.
But with the stop here in Phoenix, 10.90 @ 147.5 to 148 mph..
(same 2800' - 3500' DA)
In Vegas, 11.05 @ 145 mph.. Down 3 more mph..
Only about 1000' different in altitude but the Barometer is way down.. Results show this..
Also, out here in the deserts, there isn't much greenery so oxygen content is way down too.
This would be a 3000# car with a glide.. Problem is converters usually, because you are coming off the stop in high gear trying to move all that weight..
Some think it's so easy.. But I never see them out here racing..
Chris..
