Already planned on using "0" gauge welding cable for main positive/negative leads. Probably will be doing all the lug and terminal installations myself.
On the welding cable lugs I would sugest cutting the cables to the length(s) you need then go back to the welding supply shop & have them crimp on the terminals. Here they'll do it for free since you're buying their cable. Or if your measurements are spot on you can do right there when you purchase the cable lengths (as they say measure twice)
